Zbolt clutch linkage
Looking to replace an old 350... I know that the two piece rear seal 350/454 has provisions for the zbolt buss clutch linkage on the drivers side of the block -- does anyone know if the newer one piece rear seal 350/454/502 has it? And if so which ones exactly? Thanks!
I don't know if it is a little **** (right now the linkage is still on it), but it is above a slightly forward (toward radiator) of the filter... does that sound like what you are refering to? Thanks!
