LT1 swap, traction question
Old Sep 28, 2003 | 01:40 AM
sinner's Avatar
Car: 1992 Camaro Z28
Engine: 1995 Camaro LT1
i didnt know which section to put this question, so i put it here. i have gotten alot of help in this section.
i completed my swap (95 LT1 in a 92 Z) about a month ago. tonight was the first time i raced it, and i was excited and depressed at the same time.
i raced an 82 Z28 with a crate motor. (it was a nice car) we went 3 times, and each time i did better, but he beat me every time cause no matter how hard i tried i couldnt avoid spinning the tires.
WHAT CAN I DO????
it has a 700r4 with a shift kit, still has the traction bar thing that was stock, and has some pretty good tires.
i could tell that once i hooked up he wouldnt gain on me at all, and the final run i actually was able to gain on him some. i am very excited, i think my car has the potential to be 1 bad mo fo.
ant suggestions?
Old Sep 29, 2003 | 03:16 PM
mat89RS's Avatar
You can try a better panhard, ajustable torque arm, ajustable control arms, V6 rear shocks, wider rear tires.
Old Sep 29, 2003 | 07:26 PM
sinner's Avatar
is there an aftermarket company that makes the best parts for this?
what are V6 shocks?
did anyone else experience this with thier LT1 swap?
Old Sep 29, 2003 | 08:05 PM
TexasLT1's Avatar
Car: '92 RS
Spohn has some great parts. First things to get are LCA brackets, LCA's and Subframe connectors. The main thing I would do though is check into some drag radials. Also, what gears are you running?
Old Sep 30, 2003 | 02:23 PM
sinner's Avatar
its got the stock 2:73 gears
Old Sep 30, 2003 | 03:03 PM
TexasLT1's Avatar
Car: '92 RS
Then I'm guessing it doesnt have posi?
like I said, I would go with tires and LCA's/brackets first. That will help quite a bit. Then later on if you need it get the adjustable Torque Arm, but those go for a pretty penny.
Old Sep 30, 2003 | 07:27 PM
sinner's Avatar
no, im sure i dont have posi.
i have a richmond gears 3:73 kit, can i install a posi when i put those in, or is it something that i have to buy together?
im really disapointed, these tires were supposed to be good for this, and they were not cheap.
do the tires need to be bigger?
will drag radials perform while cornering?
ill check out spohn too!
Old Oct 1, 2003 | 02:14 PM
TexasLT1's Avatar
Car: '92 RS
GET POSI!!! That will do wonders for your traction. You could get an SLP take-off unit for $99, plus the gears you already have, and you're good to go. I would make that my number 1 priority. After that, then work on the suspension.
Oh yeah, and what tires do you have and how big are they? You said they were meant for this so if you get posi you should be good. The other thing to consider, the more gear you put under it the harder it will be to get traction. The advantage of gears is once you get the traction, then you get the better acceleration.
Old Oct 1, 2003 | 02:18 PM
sinner's Avatar
i lookked at the spohn stuff last night, it all looks like a good idea, but ill check slp tonight.
thank you.
tire suggestions?
i used to like my bridgestone potenzas
Old Oct 1, 2003 | 02:20 PM
TexasLT1's Avatar
Car: '92 RS
Can't really help you too much on tires. I'm running Goodyear Eagle F1's right now on the rear and cut a 2.0 light with 24 psi in them. I can't see getting much more improvement on that with street tires. If I had a stronger rear end I wouldn't hesitate to get some slicks, but I can't afford to replace axles or center sections right now. Nitto seems to have the best drag radials from my experience, I think they run about $150 apiece.
Old Oct 2, 2003 | 02:36 PM
sinner's Avatar
my bridgestones were 240 ea. 4 years ago
the ones i have now were 220 ea.
Old Oct 3, 2003 | 02:07 PM
Drastius's Avatar
Car: 1985 Camaro Z28
Engine: Caprice LT1
Posi and tires are your best bet. For tires it is more important to have a good tire compound than wide tires, although wide tires look nice.
Drag radials would be good, if you want an all round performance and don't care about price some Bridgestone potenaza S-03 pole positions would hook up well, or for less money some Firestone firehawk sz50ep's they last a while too.
Old Oct 3, 2003 | 04:17 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Dont waste your money on expensive aftermarket suspension items like tubular torque arms, boxed LCA's and tubular panhard bars if you dont have a working posi and a good set of tires. Get a zexel torsion posi and some 28 spline axles (if you can still get the zexel) and some BFG comp T/A drag radials and you will eliminate virtually all your traction problems.
Old Oct 4, 2003 | 12:38 PM
sinner's Avatar
its nice to see someone else from oregon!
so then i am understanding basicly i need to buy an aftermarket posi set up and axls to go with it, right?
will i need anything else to go with all that?
Old Oct 4, 2003 | 04:51 PM
Yep, SLP used to sell $99 posi units off new camaros. That is what i run, and I found used 28 spline axles on ebay for $60. Do you ever race at the Southern Oregon Speedway?
Old Oct 4, 2003 | 07:33 PM
sinner's Avatar
si i just need the axles and the posi and im set?
no, im just getting into this thing. do they have events for street cars?
Old Oct 4, 2003 | 08:11 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
in this order i would do things:
tires... if you already dont have good ones.
posi and gears (same time)
relocate LCAs
new LCAs.
Old Oct 4, 2003 | 08:16 PM
sinner's Avatar
tires are good.
so what perts do i need?
a list would be nice (hint,hint)
Old Oct 4, 2003 | 08:21 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
the gears.
a gear install kit. (all one part, look in summit)
the posi unit
LCA relocation brackets
LCAs... they either come with the hardware, or you reuse your stock ones..
umm i think thats it.
need a welder to put the brackets on, the LCAs just bolt right on, and the gears you either need the tools and know how, or take it to someone who does..
Old Oct 4, 2003 | 09:05 PM
sinner's Avatar
i looked on slponline and i saw no gears for posi, ill call em monday, dont i need different axyls too?
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
