6 to 8
Old Oct 5, 2003 | 10:00 AM
3.1LFirebird's Avatar
6 to 8
got a 88 firebird 2.8 5 speed
ive got a 92 firebird with a 305 automatic, not sure weather tpi or tbi
i am puttin the 305 in the 88 but i want to keep the 5 speed i know i need a bell housing and ive herd ill need another clutch but other than that what does the swap involve? i also herd that the 92 has an electronic speedo pickup
also could anyone tell me if the 305 is a roller block
Old Oct 5, 2003 | 05:21 PM
riffsimm's Avatar
6-8 swap
I did a 6-8 swap in my 88 firebird. took out the 2.8L and put in a 5.7L. it was harder then i thought but possible. You have to move the motor mounts,the K member is drilled for it.the front springs will hold the 8 but it will sit low.my 88 had an electric speedo so that was not a problem.new exhaust y pipe or headers.then the computer. I went old school no computer, 1 wire distribitor. it about nickle and dimed me to death there is alot of work to do just plan it all out and try to get all the parts that you will need
Old Oct 5, 2003 | 07:18 PM
cdartz's Avatar
The input shaft on your T5 is not going to have the correct spline count since it's coming from a V6 car. You really should sell it and buy one from a V8 car if you want to do the swap right.
Old Oct 5, 2003 | 08:02 PM
ok how about crossmembers or anything like that?
so basically i cant use the old tranni at all?
and if i cant anyone wanna buy a 2.8 and t5 with 75k
