Temperature switch 700R4
Old Oct 5, 2003 | 06:47 PM
Deathtrap's Avatar
Car: 1991 Firebird
Engine: 94 to 95 cam conversion 5.7 LT1
Transmission: 700R4 Mega Raptor
Axle/Gears: stock ax with 323 zexel posi
Im hooking my 94 LT1 harness with my old 91 v6 firebird harness. Temp switch wires on the tranny need be hooked back up or not ? I have a tan\blk wire and a lght\blue wire comming from switch. Any info thanks what does this switch do? Thanks
Old Oct 5, 2003 | 10:00 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Which transmission and which harness are you talking about?
Old Oct 7, 2003 | 07:28 PM
Deathtrap's Avatar
Car: 1991 Firebird
its 700r4
It 700r4 raptor tranny. 91 firebird was v6 now with 94 LT1 motor. Blending in 94 LT1 motor harness with 91 v6 harness. Trying decide wether not hook up temp switch wires on the old harness to the new motor harness with the PCM.
Old Oct 8, 2003 | 07:50 PM
Deathtrap's Avatar
Car: 1991 Firebird
its done
Its a done deal got it all wired and finished!! Thanks ALL!!Woohoo Contact!!
:rockon:
Old Oct 8, 2003 | 08:43 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
What kind of mods you have done to that LT1? I might be putting an LT1 in front of my rebuilt 700R4.
Old Oct 8, 2003 | 09:44 PM
five7kid's Avatar
The reason I was asking what tranny & harness you're talking about is the TH700 doesn't have an externally wired temp switch.
It does have a torque converter lock-up circuit and a 4th gear engaged indicating circuit.
But, I don't know what the LT1 ECM needs, or can do with the TH700 tranny. Someone else will have to handle that one.
Old Oct 9, 2003 | 11:10 AM
jmiller's Avatar
Car: 87 IROC - 67 Camaro
Engine: 383 TPI - ZZ4 TPI
Transmission: 700R4 in both cars
Axle/Gears: 3.27 - 3.36 posi in both cars
He'll have to use a brake switch kit made for 700R4 conversion to a car without computer control to lock the TC. I don't think the 94' computer can be hooked up to the trans as you stated, it is intended to work with a 4L60E. Bowtie overdrives sells the brake switch kit to lock the converter along with a trans temp gauge setup which includes a pan with a drain plug that the sensor installs into. I've had a 700R4 in my 67" camaro for 5 years now using this stuff. 3 years ago I installed TPI but didn't change this method.
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
luvofjah
Sep 3, 2015 07:08 PM
85Special
Sep 3, 2015 04:21 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
