Im going for it!
Old Oct 6, 2003 | 03:26 PM
83_Camaro_83's Avatar
Car: 1987 Z28
Engine: Tree Fiddy (modded)
Im going for it!
I have a 1983 Berlinetta with a 2.8 in it ....now we all know, that the engine has no *****....BUT i have just bought a 350 from a guy and now im really serious about putting it in after i get it cleaned up and painted (the engine) I really need to know the steps involed in doing this and materials i will need,. my school has all the tools i will need to im good in that department, but I dont know much about making the swap. I am also changing my singe exhaust to dual, i guess this would be a good time to do that too So if anyone has made the swap ( preferably in the berlinetta) can you pleeeeeeaaaasssseeeee help me out here. I know all the third gens are the same chassis, but are the mounts the same or will i have to get new ones? drill more holes? change wiring harnesses? please help me out, im Almost ready to make the swap
thanks:lala:
sorry one more thing, will i need a new tranny? i just got the regular one for a auto 2.8L v6
thanks again
Old Oct 6, 2003 | 03:33 PM
windowlicker's Avatar
It sounds like you need to do a little research, actually a lot of research, before you attempt this swap...start searching is my advice
Old Oct 6, 2003 | 03:42 PM
Car: 1987 Z28
i have looked around the forum and i havent really found a list of what im gonna need to do it :S so thats really all i need, im sure my shop teacher will help me out, but im gona wanna get parts first
Old Oct 8, 2003 | 06:59 AM
brobert's Avatar
youll need a new trans, the v6 trans has a diff bell housing. the holes are their for the v8 mounts, look right infront of the v6 mounts.
Old Oct 8, 2003 | 07:13 AM
bubbareno's Avatar
Car: black on red 92 rs
Transmission: t-5
If you live a state with strick emmison laws that might be somthing to think about. Anouther thing i was thinking... was all the wiring, rear end gears and Proper routing And mounting for the smog pump An are you going to stay with a computer? What about ignition? Im jus throwing ideas out there. Be cool an good luck.
Old Oct 8, 2003 | 12:25 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You just need one part: a complete donor car that came from the factory with a V8.
Rear end gears are one thing you don't have to change. Everything between the radiator & driveshaft has to change, however. Having a V8 already is nothing - the details will kill you.
You couldn't have searched very hard. It comes up every few weeks. Unless this car has some sentimental value, sell it and buy a factory V8 car - put your 350 in it. If it's your first car, dearly departed granny's car that you inherited, or something of that nature, then go out and find a V8 donor car and have them side-by-side; take a bunch of pictures of both before you start taking anything off.
Oh, a couple of other things:
Keep the donor car close in year model to yours, also best to keep it a Camaro.
And, a frontal lobotomy isn't a bad idea to help you cope with the project once you get started on it.
(In case you're wondering, I found thirdgen.org about 6 months after I completed mine.)
Old Oct 9, 2003 | 07:24 PM
Car: 1987 Z28
Yo man, you seem to have alot of the answrs i need for my project berlinetta. Do you got msn? cause im usually on there and not here, if you do add me, your a good guy to know when doing this
msn - bionicle911@hotmail.com
Old Oct 9, 2003 | 07:35 PM
brobert's Avatar
I think it also depends on what kinda v8 you want to put in, like the old style,carbed , no computer, no emissions would be a hell of alot easier than a fuel injected settup would be to put in..
Old Oct 11, 2003 | 12:01 PM
Car: 1987 Z28
the 350 i bought was a 78 carbed, so yeah.....
Old Oct 19, 2003 | 02:20 PM
Z-Monkey's Avatar
Car: 83 Brlntta in Z28 clothing
Engine: 305 LB9 POS until 350....
Transmission: hurting 5 spd- Crunchy...
350 swap into an 83
What kinda trans do you have on your 83? (I forget stuff...) I'm looking to swap a 350 into my 83 too, but I have a manual with a non-hydaulic clutch and I've been told that I can't put headers on the new engine unless I switch to a hydraulic clutch set-up. I know this doesn't help your 6 cylinder to 8 cylinder dillema, but maybe it'll avoid some tool throwing and vulgarity in the future.
Z-Monkey
