GoAutoCenter's 300HP TPI Engine
Old Oct 16, 2003 | 12:46 PM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
300HP TPI Engine 87-89
Whats everyones opinion on this motor? I'm thinking this would be my best bet to replace my high miled 305 TPI. I figure, buy this motor, drop it in with all my accessories from the 305, the TPI off the 305(bigger injectors down the road) and have a chip made. I alos think I'll be dropping this in mated to a Tremec TKO Trans. Do you guys think this is a good setup? Also, been thinking about converting it to a splayed 4 bolt main, since its only a 2 bolt, and I may supercharge it down the road.
Old Oct 16, 2003 | 06:57 PM
bes217's Avatar
Looks good to me. I was actually looking at this motor for my car.
Old Oct 16, 2003 | 07:12 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I bought one almost two years ago.
It currently has over 40,000 miles on it with no troubles and it runs great and makes lots of torque.
In my opinion, though, if you're gonna use a power adder (supercharger or nitrous), I'd get a 4 bolt with forged pistons (like the ZZ shortblock) and put some afr 190's on it.
btw: I'm using a Tremec TKO as well.
-Rich-
Old Oct 16, 2003 | 11:45 PM
bes217's Avatar
I have been looking for the zz shortblock but have not been able to find it anywhere. Do you know a site that has them for sale?
Old Oct 17, 2003 | 12:01 AM
91DropTopTA's Avatar
Car: 91 Trans Am Convertible
Engine: 300 HP 350 CI
Axle/Gears: Drums?
I like mine. I have almost 400 miles on it so far, and it is running great. I ended up having to buy a scantool to get it tuned, but that was the best 140 I ever spent.
Old Oct 17, 2003 | 10:18 AM
Car: 92 Camaro RS
bes217:
Jeg's sells the ZZ shortblock for $2k:
http://www.jegs.com/cgi-bin/ncommerc...36&prmenbr=361
Scoggin-Dickey as well:
http://www.sdpc2000.com/cart.asp?act...tart&catid=514
-Rich-
Old Oct 17, 2003 | 03:38 PM
jmiller's Avatar
Car: 87 IROC - 67 Camaro
Engine: 383 TPI - ZZ4 TPI
Transmission: 700R4 in both cars
Axle/Gears: 3.27 - 3.36 posi in both cars
http://www.sdpc2000.com/cart.asp?act...tart&catid=123
-Rich-
1992-93 Caprice, Fleetwood 5.7L / 350 GM Goodwrench Crate Engine $15xx.xx
I bought this motor from SD 2 years ago and put it in my son's truck. Back then the motor cost around $1375.00. If I were you, I would look at Scoggin-Dickey's website and check it out. The price is much lower and appears to be same engine. Put a ZZ4 cam in it for $184.95, and you've got a very nice motor for under $2000!!!! The oil pan comes with a stupid oil level sensor hole, you'll have to plug up.
Old Oct 19, 2003 | 11:24 AM
Engine: Mild 350
Instead of plugging up the oil level hole, could i use my old oil pan off the 305? Pan is in excellent shape.
Old Oct 19, 2003 | 08:45 PM
Car: 92 Camaro RS
Yeah, the 305 pan will fit.
-Rich-
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Sep 3, 2015 10:56 PM
R3500
Aug 17, 2015 12:16 PM
Sanjay
Aug 12, 2015 03:41 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
