my journey begins
Old Oct 14, 2003 | 12:54 PM
87camarodan's Avatar
my journey begins
Hey everyone, I am going to start my LT1 swap into my 87 carbed 5 speed camaro soon. I should be getting the LT1 and 6 speed later this week. I wont be doing very much swapping quite yet, but at least I will have the motor and tranny, then I can start collecting parts.
My plan is to get the motor and transmission, and start figuring out everything I need, Im going to get a hotcam kit and headers, a 4th gen radiator, A/C delete pulley(part number??). Nitrous is probably in the foreseeable future as well
what do I need as far as fuel pumping? I have a mechanical fuel pump in my car currently, any recommendations about inline fuel pumps out there? Im not sure about gph and pressure and that stuff, what about my throttle cable? and from what ive read there is a mechanical to electric speedometer changer, so Im guessing ill need that.
does the transmission mount from the 4th gen bolt onto my frame at the right places? and will my driveshaft work?
thanks for any help, I hope I wont have to ask too many questions during this swap.
Old Oct 14, 2003 | 01:22 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
You have a few options for fuel delivery. Check out www.racetronix.com or supporting vendors for more details. I would reccomend modifying the fuel system for a return line and using the inline tank pump. I am running a walbro GSS340 which is a significant upgrade over teh stock pump. The advantage of running this system is the the fuel can circulate and stay cool. Otherwise you will have to modify the fuel rail on the LT1 setup.
As far as the trans mount read the page here at http://www.skulte.com/T56.html there is great information there.
Drive shaft will work.
Good luck.
ZZ3Astro
Aug 13, 2019 12:57 AM
starliner
Feb 9, 2016 08:18 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
Marc Brown
Sep 28, 2015 01:40 PM
scottmoyer
Sep 7, 2015 07:06 PM
