LT1 Gen 2
Old Oct 14, 2003 | 11:18 PM
1989 Iroc-Z28's Avatar
Car: 1989 IROC-Z
LT1 Gen 2
Hi, I'm thinking of swapping in a 395hp LT1 it comes with alloy heads, water pump, drive plate, new LT4 injection, harmonic balancer, distributor. Would I have to modify the transmission at all? And would I need anything else besides what the motor comes with? Is the swap easy to do? Thanks for the help.
Old Oct 15, 2003 | 10:21 AM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Depends on how hard you run it. That power will probably twist your trans to pieces.
You probably will need to upgrade your fuel pump. Make sure the engine comes with the PCM. You may have issues with the mechanical speedometer also.
Old Oct 15, 2003 | 10:32 PM
KYL98's Avatar
Car: 1991 Z28
The trans is good till about 400hp...so its close to the edge HP wise. Plus it really depends on the condition of the trans itself. If its worn out...or has alot of miles....I would replace or rebuild it. Putting the engine itself in is easy....its the wiring that can be tricky. But if you take your time and are mechanically inclined....its not too bad. You will have to find an adaptor for your tranny. Im sure painless wiring makes a harness/adapter to make the LT1 co-incide with the 700R4. Good luck.....
Old Oct 16, 2003 | 09:38 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
you will need to rebuild it eventually.. my 4l60e that came with the LT1 just bit the dust... broke a gear.. and I have just bolt-ons..
made room for the six speed though...
midge54
Dec 27, 2019 04:14 PM
midge54
Aug 29, 2015 09:51 PM
sreZ28
Aug 14, 2015 07:48 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
