New Opti and still having problems
Old Oct 19, 2003 | 11:25 AM
N.W. T/A's Avatar
Car: 87 WS6 T/A
Engine: 97 LT1
I replaced the Opti and i'm still having problems. When I accelerate mild to hard it's like riding a bucking Bronco and like it's losing electrical power. When I let off the gas it goes away. Any ideas ? ......... thanks
Old Oct 19, 2003 | 02:10 PM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
Just a thought....but could it be a loose wire some where that moves upon accelaration? Try double check all those including the wires at the plugs. You may even want to unplug and replug everything back in.
Old Oct 20, 2003 | 09:55 AM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Is your water pump leaking? Sounds like the opti is getting wet. You should get a diag scan to help you zero in on the problem.
Old Oct 20, 2003 | 01:43 PM
TexasLT1's Avatar
Car: '92 RS
check your o2 sensors. when mine went out it was running pig rich and had the same problem. If thats not it, then its something with the Opti. could be loose wires, water like previously mentioned, or you might have the same problem I did. When I put my opti back on after a cam swap, the dowel pin got pushed in slightly too far, went to put the opti back on and it didn't get located on the dowel pin correctly. ended up being about 20 degrees off. idled alright, drove like absolute ****.
Old Oct 20, 2003 | 06:19 PM
mat89RS's Avatar
I would look at the fuel delivery system, check fuel filter fuel pumps, injectors and grounds , could be a bad coil ?!?
Old Oct 24, 2003 | 09:37 PM
AT4 T/A's Avatar
Car: 1989 IROC-Z
Engine: L98 350
Transmission: New 700r4 Done by 11/14/07!
Same thing you're describing happened to my IROC. After a ton of fiddling around, it turned out my brand new Accel coil's epoxy casing had cracked. Bad coil.
On a side note, the Accel replacement coil came loose in the housing after about a month. Don't even get me started on thier ignition module. I won't buy Accel ever again.
Old Oct 24, 2003 | 09:50 PM
N.W. T/A's Avatar
Car: 87 WS6 T/A
Engine: 97 LT1
I have a Coil ordered (GM) I took it back to the shop and they looked everything over, nothing found. It's not throwing codes and they claimed to have checked all the sensors. Think i'm gonna bite the bullet and take it to a local shop that has a Dyno so they can create the problem under load conditions. There goes my money for my 4.56 gear install, oh well
Old Oct 28, 2003 | 05:42 PM
David Petersen's Avatar
How about the trottle position sensor? Is it maybe broken, wire loose?
Old Nov 3, 2003 | 08:53 PM
wm_sorg's Avatar
Did you check your fuel pressure? Have you replaced the fuel filter recently?
BILL
Old Nov 3, 2003 | 09:21 PM
N.W. T/A's Avatar
Car: 87 WS6 T/A
Engine: 97 LT1
TPS checks out fine..... Fuel pressure is at 43 with key on, 38 at idle and 43 at WOT. I've got a date with the dyno next week. I'll post results......... Thanks
Old Nov 3, 2003 | 09:34 PM
sinner's Avatar
Car: 1992 Camaro Z28
Engine: 1995 Camaro LT1
I had a similar problem, i had fuel pressure and everything. It turned out my injectors were clogged.
Old Nov 3, 2003 | 10:26 PM
N.W. T/A's Avatar
Car: 87 WS6 T/A
Engine: 97 LT1
I had the injectors flow tested before I put them in.... I did run it low on gas a few times and they could have picked up some crap from the bottom of the tank. I'll check them out tomorrow..... Thanks
Old Apr 19, 2006 | 08:07 PM
Firebat's Avatar
just curious 2.5 years later...did you find out what the problem was?
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
