Lt1 engine question
Old Oct 25, 2003 | 11:32 AM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Lt1 engine question
I am thinking about buying an Lt1 for a build up soon ,and I want to make it carberated, I noticed that there are alot of different things on these engines though
1. since the iginition system is different can I just throw a vaccum advanced dist. in there or would i have to modify something.
2.would I have to buy the Lt1 manifold for carbs, or can I just throw any intake that fits centerbolt heads on there.
3. Will my water pump, and serpintine brackets from a 305 tbi motor fit on there or no.
I appreciate any help I can get on this , Thanks.
Old Oct 25, 2003 | 12:26 PM
cdartz's Avatar
If you have a 350 in your car now, why do you want an LT1 block? You mentioned using a distributor. LT1s don't use one.
Old Oct 25, 2003 | 12:39 PM
IROCaholic's Avatar
Car: 89 Camaro RS
I only want it because the one I found is built. They use opti spark right? Yeah I was just wondering, so its pretty much not possible to run a carb on one huh?Thanks
Old Oct 25, 2003 | 09:37 PM
_max_'s Avatar
you can convert them to a distreributer and carb if you want too
www.paceparts.com tech support dude is a d***k head
Old Oct 25, 2003 | 10:00 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
You could use the longblock, provided you use the correct gmpp intake for the LT1 with a carb, they have two models one LT1 one LT4, pick which based on what heads are on the motor, you'd just drop a vacuum dist in there by changing the gear for one with a billet cam, other than that you'd need the LT1 accessories.
midge54
Dec 27, 2019 04:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
