what came with 400" smallblocks??
Old Oct 27, 2003 | 11:13 PM
RoadRacer's Avatar
There are a few good wrecking yards near me and I'd like to find a decent 400" block.
What years and cars/trucks came with 400s? Any links with this info?
Also, isn't there an external way to tell the block (freezeplugs or something)?
Thanks!!
Don
Old Oct 28, 2003 | 06:14 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They came in 70-76 full-size cars, A & G bodies; some in trucks and vans as late as about 79 or 80.
There was never a 4-barrel version. All are 2-barrels.
The early ones had 3 freeze plugs down the side. Those mostly also had 4-bolt main caps. They are the blocks with less meat around the main webbing. Later ones (73 up) had 2 freeze plugs in the side, 2-bolt main caps, and a little more metal around the mains.
All have a harmonic balancer with a divot taken out of it. That's the best way to spot one, except for casting numbers.
Castings are 511, 509, & 817. There are no others that I know of. Here's a 509 casting.
Attached Thumbnails what came with 400" smallblocks??-block-casting-number.jpg
Old Oct 28, 2003 | 06:16 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Here's a 400 balancer.
Attached Thumbnails what came with 400" smallblocks??-400-balancer-closeup.jpg
Old Oct 28, 2003 | 09:57 AM
Drastius's Avatar
Car: 1985 Camaro Z28
Engine: Caprice LT1
I got mine out of a late 70's blazer, best way I could tell was the holes they had drilled in the balancer. Too much crap on it too see the serial number.
Old Oct 28, 2003 | 12:18 PM
CaddiBird's Avatar
Car: 89 base 'Bird
Engine: 507ci Caddy
Transmission: BOP TH400
Just a tip when you do go to the yard to find one a good way to see the casting numbers is to get one of those brushes for cleaning the inside of copper fittings before they get soldered, a good flash light and a spray can of carb/brake cleaner.
Old Oct 28, 2003 | 01:41 PM
RoadRacer's Avatar
Thanks a lot everybody!
Don
Old Oct 28, 2003 | 05:51 PM
cac91's Avatar
Good luck finding a worthwhile engine in the junkyard. You'll have to show up at the right time to get one. They are in demand and have been in demand for quite a while.
Old Dec 6, 2003 | 09:29 PM
chadgore's Avatar
i got a 400 sbc out of a 1974 caprice and it had a 4 -barrel.
Old Dec 7, 2003 | 08:54 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Didn't come from the factory with a 4-barrel, even if there was one on it when you got it. Used to be a rather popular swap to just stick a 4-barrel intake and carb on motors; since the motor itself (block, heads, cam, exhaust) was all the same between a 2-barrel and a 4-barrel. All you had to do was find a 350 4-barrel car in the junkyard.
john204481
Sep 7, 2015 03:22 PM
blackroc68
Sep 1, 2015 08:01 PM
Jack G Jr
Feb 24, 2005 05:44 PM
hotwheels
Mar 12, 2002 08:57 PM
WillDC7
Mar 8, 2002 02:58 PM
