Whats the deal w/the ZZ4 water pump pulley
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
I have a 92 (originally 305 TBI) Camaro, got the ZZ4 installed and my old water pump pully (serpentine system) doesn't fit. The holes are a little bit off. Does anybody know what the deal is??? I plan on just elongating the holes in the original serpentine pulley to fit those of the new ZZ4 water pump.
Who else had this problem with their ZZ4? What did you do?
Car: 92 Camaro
Ok I am a dumbass for not seeing that. The serpentine belt goes UNDER the pully whereas the old v belts go OVER it.
Is there a way to route the serpentine belt over the top so I dont have to swap pumps? Maybe just swap belts. I just dont want to void the Crate engine warranty by swapping pumps.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
swapping pumps shouldnt void your warranty. they are a external accessory.
its only 4 bolts and 2 gaskets.. like a 5 min job.
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
Why would you need to swap to a reverse rotation water pump???? I'm kinda confused on that, I thought the LT-1's used the reverse rotation, not the TPI's or TBI's.
Car: 92 Camaro
you are thinking of reverse flow, not reverse rotation like we are.
Car: 91 Camaro Vert
with a V belt setup the water pump pully and the crank pully turn the same way
with a surp belt setup, they turn diff directions.
the water flow is the same direction with both of them. but the way the pump turns is diffrent.
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
Street Lethal
Aug 12, 2015 11:33 AM
