Not a 3rd gen question but maybe you can help
Old Nov 7, 2003 | 08:34 PM
megaracerx's Avatar
i have a 1979 Firebird (formula) 301 ci. 4 bbl. 4 speed w/ hurst shifter. from what i understand it a rare car...only 1700 or so made and it has alot of trans am options. it has a little body rust (not bad) but when i bought it it started right up, and on day it just cranked and cranked and cranked.... i called the guy i bought it from..." it needs a carb..."... but then he moved outta state... so do you think he telling the truth? i'm a novice wrencher...and i dunno much..yet.. :-) so will a new carb fix it?
or is it jus
Old Nov 7, 2003 | 09:41 PM
CamaroFreak406's Avatar
Car: 1991 Formula
Engine: 350 firebreathing inches of Small Block Chevrolet
Transmission: A 700R4 that has trouble handling the formentioned 350.
Well as long as it not a computer conrolled car (which yours isn't) there is two things that won't let it start Spark and Gas. So it maybe a carb. so just pour some gas down the carb. (about 1/4 - 1/2 cup) and see if it starts if it does then it's a carb or fuel pump. If that doesn't work check spark and timing if that doesn't it is a piece of crap.
Good luck, Garrett
Old Nov 7, 2003 | 09:55 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
are we forgetting about air and compression?
Old Nov 7, 2003 | 10:41 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
try starting fluid instead, 3ft flames out the carb aren't good for anyone. You're right, your car is rare, it still has the 301 in it
You can check for fuel delivery by having someone crank it & look into the carb.
Also check fuel filter
Also do the screwdriver thing & check for spark. If none, pop the cap & make sure rotor didn't break, then get ignition module checked for free.
Check wires going to distributor.
Old Nov 11, 2003 | 12:59 AM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
if the engine turns and you have good compression (you can get a compression guage for $15 at harbor frieght tools) , then you havn't much to worry about.
welcome to the wonderful world of wrenching!!
get yourself a haynes or chiltons repair manual, those are the best books to start with. After awhile, you won't even need to use them.
1992rs/ss
16
Jan 28, 2016 09:58 PM
69 Six Pack
Oct 5, 2015 07:51 PM
redmaroz
Aug 16, 2015 11:40 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
reiderz iroc
Aug 13, 2015 04:57 PM
