Engine swap,what needs done to computer
Old Nov 20, 2003 | 02:32 PM
snowman89's Avatar
Car: 1989 IROC-Z Camaro
Engine: 5.8L 355
Transmission: T-5 5-speed
I'm swapping engines in my 89 IROC from a 350 TPI to a built 350 short block, with good heads, and cam, and I am keeping the TPI on it. Does anything need to be done to the computer with this upgrade. What will I need to do. If I need to send the computer somewhere, where to. Can i buy something that I cna do it with myself. thanks
Old Nov 20, 2003 | 03:44 PM
87camaroz28310's Avatar
Car: 87 plane jane with gfx
Engine: 350 worked vortec head .515 .515 cam and 1.6 rockers and shorties for now til i can afford the supercomps
Transmission: super t-10 or t-5
Axle/Gears: auburn with 3.42 stock axles
you can order a chip from slp or jet performance and it will be the prom an you can do it yourself. you might want to get a fuel pressure regulator and maybe a different maf sensor too
Old Nov 20, 2003 | 04:32 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Engine swap,what needs done to computer
The programming is a replaceable in your ecm (computer) so there is no need to sent it anywhere. Two screws remove a conver that allows access to the memcal. It's the blue devise under the access panel. Searching around in the Prom Board will reveal lots of info about programming, and how you can do your own. The only way to really optimise the computer is doing your own tuning.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
jharrison5
Aug 19, 2015 05:53 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
