Anybdy drop their motor out the bottom?
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
Like unbolt the k-member and all? I need a new k-member, but I think I'm gonna wait till I do the motor swap to do it, but would there be any problem just dropping them out the bottom at once, then sliding the new motor and k-member into place? Or would it be easier to do it the conventional way?
Transmission: 4L80E/4L80E
A while back somebody had a photo of the engine having been taken out that way by a shop they had working on their car. It was an LT1 or LS1 swap, IIRC, so taking it out that way made a little bit of sense.
The main issues I see are getting the body up high enough to clear the engine, and having a non-roller body while the engine is out.
Car: 1991 Z28 Camaro
Transmission: 700R4 that will magically turn into a 6 speed one day.
OH yeah I agree that'd it be easier, but since I had to change the k-member anyways, I figured maybe I'd just take em out as one piece. But I don't think I can get the car high enough with the jack and stands that I have. So out the top it is.
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
that's how I got my engine out without an engine lift! what a bad idea that was! i still have the engine though.
I didn't remove the K member, I just unbolted the heads and transmission and disconnected the mounts, then I tipped it out through the transmission tunnel, it barely made it. I still did quite the same thing, lifted the car high enough to clear the motor. I prefer to use an engine lift any day!
evilstuie
Jan 9, 2020 08:29 PM
theshackle
Mar 5, 2017 06:37 PM
