flyweel on a 305
Old Dec 17, 2003 | 01:38 PM
cammy's Avatar
Car: 80's somting Trans AM
Engine: 5.0L H.O.
Axle/Gears: not sure yet
flyweel on a 305
i have a 305 and it was out of an 89 impala it was of cores an auto but now im putting it in my car wich is i want to keep a manual but there is a lip on the end of the crank shaft that wont let me put the flywell on.
the flexplate used to rest on it but with flywels thay dont rest on that and i dont know how to get it off or if it even comes off am i out of luck and stuck with going to find a new motor or can this be saved.
to get mor detaled the flywell center hole is 1 and some odd inches acrost the lip tha the flex-plate was resting on is 2 and a haf inches acrost
any help is apreasheated
Old Dec 17, 2003 | 03:38 PM
Guest
Guest
Posts: n/a
What year is your car?
Old Dec 18, 2003 | 01:35 PM
cammy's Avatar
Engine: 5.0L H.O.
my car is a 92 but that doset have anny thing to do with this motor because it's not from my car i found the engine block number maby this can help 14010203
Old Dec 19, 2003 | 03:56 AM
dennis6's Avatar
Car: 1991 Camaro RS
www.mortec.com
Old Dec 19, 2003 | 12:57 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
The engine is an 80-85 two-piece rear main seal; the flywheel from the 92 is for a one-piece RMS engine.
You'll need to aquire a flywheel for an 82-85 305 F-body.
Pete
Old Dec 30, 2003 | 07:27 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i have older flexplate if you need one, there were no manual tranies in impalas and such so its technically called flexplate and not flywheel
good luck
Old Dec 30, 2003 | 10:18 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
He wants to keep it a manual so it needs to be a flywheel.
As was said, 82-85 305 F-body is the correct flywheel aplication you need.
pjsparts
Oct 29, 2025 06:39 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
