good heads ?
Old Dec 22, 2003 | 11:18 AM
fyrechikyn's Avatar
good heads ?
does anyone know how good the heads of of an 85 -89 corvette are a guy wants so sell them and said they were vortec heads but vortecs didnt come out till 96 right?
Old Dec 22, 2003 | 11:29 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Since you already caught him in the lie about the "Vortec" thing, how do you know that any other word out of his mouth is the truth?
There's one other lie in there too. The heads that came from the factory on the motors in 85 Vettes at least, which may or may not having anything to do with whether these "came out of" or "off of" some Vette (the back seat perhaps? maybe the cargo area? sitting on the roof? "came out of" or "came off of" is pretty vague) are different from the ones that came from the factory on the motors in later ones. The early ones were cast iron, the later ones were aluminum.
So now that you know clearly that this person is plainly trying to rip you off, get the stars out of your eyes about the supposed "Vette" thing, and do some research. Ignore the newbie "Vette" BS and find out what they really are.
Get the head casting numbers. Those tell all. There are no more secrets once you have those.
The mere fact that the heads are "out of a Vette" (probably the single most popular sucker line in all of hot-rodding) doesn't guarantee that they're particularly good for anything. Even if the factory had put them in the Vette before they were taken out of it, they're still fairly ordinary heads, except that in some of those years they were aluminum.
Old Dec 22, 2003 | 12:17 PM
fyrechikyn's Avatar
im not falling for any of his bs i was just wondering if they were decent heads or not
Old Dec 22, 2003 | 12:28 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
If they are the L98 heads I wouldnt bother. There are too many cheap aftermarket heads nowadays that flow much better unless he is going to give them to you...
Old Dec 22, 2003 | 01:06 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Get the casting number. Nobody can tell you whether they're any good or not, since everything you have been told about them is BS.
Old Dec 22, 2003 | 01:34 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Be aware also that truck motors from Chevrolet were called "Vortec" before 1996. Technically someone could sell a set of "Vortec" heads and they would be accurate but these would NOT be the heads you are looking for. You are looking for two casting numbers, 12558062 and 10239906. An easy tip to identify the two from others is the heart shaped combustion chambers. Casting 12558059 is also a "Vortec" truck head built after 1996 but the undesirable 305 version.
Old Dec 22, 2003 | 01:38 PM
wesilva's Avatar
Transmission: 200R4
Heart shaped Combustion Chamber
This is the chamber your looking for.
Old Dec 22, 2003 | 02:23 PM
fyrechikyn's Avatar
thanx for the info guys hey wesliva are tyhose pro action heads pretty good ? ive seen them on ebay and was wondering if theyre as good as the new modified gm vortec's
Old Dec 22, 2003 | 02:55 PM
wesilva's Avatar
Transmission: 200R4
Trying them for the first time myself. Will post some hp figures at the beginning of the new year when I can get them dynoed.
Visually, the casting were very nice and clean....no burrs or flaws. The Kiwi's must know there stuff (cast in New Zealand). I built mine up with Manley Street Flo valves and Comp Cams springs & retainers. I have fairly extensive port work to the exhaust side only with pocket work on both the intake and exhaust. Backcut valves on all 16.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
