what engine do i have?
Old Jan 4, 2004 | 11:10 AM
yellowdart's Avatar
hey guys i need help. i dont have the right starter on my car, but i cant get the right one, because my car doesnt have the original 305, but it has some 350 in it. and i dont know what its from, the car is an 89 formula, and the engine is something that i dont know. the only numbers i could find on the block was...
it either said
638 or if that was upsidedown it was
BE9 or
8E9
i need to find the numbers if those arent right. so if anyone has anyhelp
thanks
Old Jan 4, 2004 | 12:03 PM
ede's Avatar
ede
run the numbers at www.mortec.com
Old Jan 4, 2004 | 01:05 PM
yellowdart's Avatar
hey thanks,
im on my second starter (third including the one that was on the car when i got it). i looked at those numebers and i came up with its from a chevy 350 87-95. the number was 14093638. does this sound right to you? when i got my new starter, i brought in the old one and matched it up, and i guess that was off of an 84 camaro 350. so the starter has play when i put it in. do you think there is supposed to be play. ok, its like the holes in the starter for the bolts are alittle to big, like one bolt size, but then the threads are right into the block, so im pretty sure the bolts are right. is there supposed to be play on the them before they are tight. if you loosen it alittle, it moves enough so that it engages, or simply doesnt, it will just spin..... any thoughts apprecaited... anyone?
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
