083 heads worth anything
Old Jan 7, 2004 | 09:42 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Just wondering if the 083 heads off an L98 will respond well to porting/polishing and what could I really expect out of them or is it just worthwhile to go aftermarket.
Old Jan 8, 2004 | 12:52 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Probably the best factory heads to work over.
A set of Pro Lightnings or World S/R Torquers would probably work slightly better, and unless you do the work yourself, would cost less than working over factory heads.
Old Jan 8, 2004 | 01:25 AM
xpndbl3's Avatar
Car: 1984 Z28
i am assuming that these could possibly make a 400HP 355 engine with a larger cam and some port work? or would they not flow enough? bigger valves needed etc?
Old Jan 8, 2004 | 09:25 AM
five7kid's Avatar
Ported 083's with proper exhaust, cam, induction, etc., would make 400 gross flywheel HP easily.
Old Jan 8, 2004 | 12:07 PM
xpndbl3's Avatar
Car: 1984 Z28
i was thinking along the lines of the 274XE cam, or would you have a better recommendation. It'll be going on a Performer RPM intake, with a 750 holley on top. Right now it's a 2400 stall'd 700-R4, but can go to a 3000-3500 stall'd TH350 if need be later on. I already have long tube headers, H-pipe, and dual 2.5inch exhaust so that's been taken care of as well. Full MSD ignition as well. Just concentrating on the motor first. I want 400HP minimum and was thinking these would be a great excuse to port up compared to buying vortec heads, etc.
Old Jan 8, 2004 | 01:23 PM
five7kid's Avatar
Sounds like a good plan to me. Porting, upgraded valve springs (follow Comp recommendations for the cam), and I'd have screw-in rocker studs installed while you're at it.
Chuck84TA
Jul 15, 2016 09:05 PM
gta90
Sep 15, 2015 04:00 PM
Streetstuff
Sep 7, 2015 09:23 AM
509 camaro fan
Sep 6, 2015 10:43 AM
