cross fire 305 to a carb 350
Old Jan 12, 2004 | 10:02 AM
youngster's Avatar
is it hard to swapp a cross fired 305 to a carb 350.
What all would i need to do this.
Old Jan 12, 2004 | 11:51 AM
kevinc's Avatar
Car: 1982 Z28
Really easy if you're good with tools and have decent mechanical ability. Really difficult if you're a retard. Time consuming either way.
You'll need a 350, carb, non-computer distributor, and wiring diagram so you know which wires to cut and which ones to keep.
If the car has a TH200C trans, you'll want to replace that with a TH350 or TH700R4.
Old Jan 12, 2004 | 02:58 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
If you just do a regular carb (non-computer controlled) all you need is a 12 volt keyed wire to your HEI power terminal, ground and 12 volt keyed to the choke, and your starter & alternator wiring. That will at least get it running & driving. The only other thing you may want to add are gauge senders, and wiring for AC if you have it.
Old Jan 12, 2004 | 05:50 PM
haste's Avatar
Car: 82 trans am
Engine: 305 crossfire injection
Transmission: 3spd auto
Here's another question: could you swap a 305 cfi to 350 carb and still pass smog in California?
Old Jan 12, 2004 | 06:36 PM
Yes. Provided that the 350 carb motor is the same year or newer than the chassis in which it is installed, and all of the emissions related components are swapped along with the motor (canister, cat, EGR, computer, ect.).
Old Jan 12, 2004 | 09:49 PM
kevinc's Avatar
Car: 1982 Z28
In the case of the '82 F-body isn't this ruled out, given there was no 350ci engine offered? Just asking for clarity's sake, as I don't live in CA and won't any time in the forseeable future.
Old Jan 13, 2004 | 01:01 AM
No, as long as the engine is from a newer car, with all emissions equipment intact it is still legal. It is the engine that must meet a specific emissions test, not the chassis.
Old Jan 14, 2004 | 01:50 PM
haste's Avatar
Car: 82 trans am
Thanks for the replies TKO and Kevin.
I have an 82 TA crossfire and have been wanting to slam a 350 in it. Last weekend I found an 85 Suburban 350cid, Edelbrock Carb with a 4-spd AT for $800. I'd like to use that Edelbrock Carb since it's 1 month old compared to the CFI intake that's 21 yrs old. Would I gain more than I would with the Carb than the CFI?
Old Jan 14, 2004 | 01:51 PM
haste's Avatar
Car: 82 trans am
Another question, is there a place on the Internet that I can read up on the Smog laws and what i'm trying to accomplish?
Old Jan 14, 2004 | 02:04 PM
haste's Avatar
Car: 82 trans am
Old Jan 14, 2004 | 03:13 PM
kevinc's Avatar
Car: 1982 Z28
I dumped my CFI years ago. If you're willing to work on it, CFI isn't a bad system but you won't break any speed records. The computer is slow as mud, the intake needs porting, etc.
The CFI computer won't know how to manage the carb, so it won't be happy. You'll need to either swap in the Suburban's computer and wiring, or go non-computer in which case you'll have trouble passing emission testing. If you go non-computer you'll need some way to manage the transmission's torque converter clutch lockup, there are manual harnesses out there.
The Suburban's cam is probably crap, I'd swap it while the engine's out.
theshackle
Sep 17, 2020 08:26 AM
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
st.evel07
Aug 13, 2015 06:15 PM
