lt1 heads vs lt4 heads - stock
Car: 1983 Camaro
Engine: Lt1 (383 project)
what's the actual difference between stock lt1 heads and stock lt4 heads?
because i got the cc306 cam, and i looked at a head job for my current stock ones , and for full race they wanted $1500. and for a mild port it was $1100, this is including other work and parts also... valves etc.
But i was wondering if the lt4 heads have more of a flow , or have a larger size port stock... would these lt4 heads be a good choice for me ? that i could later port out more possibly? i dont know much about these lt4 heads...
thanks
thanks
Re: lt1 heads vs lt4 heads - stock
thanks
thanks
*Edit*
Ok, found the numbers.
LT1: 170cc, 1.50/1.94 valves, 212 CFM
LT4: 195cc, 1.55/2.00 valves, 240 CFM, .10" higher intake port
Here is a good site that lists all of the differences between the LT1 and LT4.
Car: 1983 Camaro
yea
thats exactly what i was thinking, i want to get a set of lt4 heads, and get a decent port job on them later down the road. but right now i have cast iron heads , stock, so ill get the lt4 heads and run on them for my first year runnin the car, and as i save ill get them ported down the road. Just cant afford a full port job right now, especially on cast iron heads..
1988iroc350tpi
Aug 14, 2015 07:52 PM
