belt for ac +smog removal
does anyone know the belt number that i could use to remove my ac and smog with out using an ac delete pulley. i believe it is the one off a newer 4.3 litre truck or something. does anyone know.
Car: 89 rs
Engine: 305 supercharged
Transmission: th 700
I gutted THE PASS SIDE BRACKET OF THE A/C and smog and then changed the tensioner pulley to a grooved one ... i did also cut up the a/c bracket to remove as much as possible without weakening it where the tensioner was. then the belt was ran from the crank... around the p/s...then around the alt....then across and around thetensioner then around the water pump ...and ending at the crank.....
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
