V6 TO V8 swapping
Old Jan 23, 2004 | 06:30 PM
casper975's Avatar
Car: 1989 Camaro RS
Engine: v6
Transmission: manual stock
V6 TO V8 swapping
I know this question has been asked already but here go's,
I have a 1989 Camaro RS with the 2.8 V6 with a 5speed manual and I have a 1986 Camaro Z28 with the automatic V8 so what all do I need to take out of the Z28 to put in the RS, the Z28 is in bad conditon and I dont have a title thats why Im wanting to put the V8 in the RS and its in perfect condition except for the V6 is ready to blow,
Old Jan 23, 2004 | 07:03 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
ecu, motor mounts, tranny, exhaust, all wiring. that all i can think of.
oh, and of course the v8
Old Jan 23, 2004 | 09:02 PM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
dash,harness,engine,harness,ecm and of course the drivetrain start on friday driving on sunday!
Old Jan 23, 2004 | 09:12 PM
casper975's Avatar
Car: 1989 Camaro RS
Engine: v6
So I will have to put the automatic tranny in it instead of the stick thats in it know and how hard will it be to put in the wiring harness
Old Jan 23, 2004 | 11:14 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i'm really not sure you should be tackling this by yourself if you're asking these questions....i'd go find some knowledgeable friends to help you out and i'm sure things will go smoothly then. no v6 trans will work on a v8 motor in thirdgens....so either by a v8 T5 or use that auto trans from the v8 then.
Old Jan 24, 2004 | 02:58 AM
nadster's Avatar
Car: 89 RS
Engine: 2.8 (the cruiser)
Transmission: 700R4 (TransGo Kit, VetteServo)
Change the springs too. I've had some suspension guys tell me that swaping sway bars for the bigger ones (if they are) would help. Not sure on the rear springs though. At least you have a doner car.
-Dan
Old Jan 24, 2004 | 09:50 AM
casper975's Avatar
Car: 1989 Camaro RS
Engine: v6
Well I will have help doing it but my main consern is the wiring harness how hard its going to be to hook everything up
Old Jan 24, 2004 | 10:28 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Rear springs are same between the 6 & 8 cars.
Pulling the harness is relatively easy. There's a junction under the pass side kick pannel. THis is where the the harness to teh dash connects to the engine bay harness. I had to stick my arm under the wheel well cover to route it out. Other than that, easy. The blower harness was let in along w/the vacuum line for it.
I did find on mine (2.8 harness) the water temp, oil pressure, & tach leads came in on the driver side harness , by the brake booster.
Old Jan 24, 2004 | 02:41 PM
gen3z's Avatar
the springs may look alike but they do have different spring rates for suspension packages!
Old Jan 24, 2004 | 03:58 PM
casper975's Avatar
Car: 1989 Camaro RS
Engine: v6
Will the 5speed tranny from the v6 work on the v8
Old Jan 24, 2004 | 04:33 PM
mw66nova's Avatar
Engine: 7.0L
no
Old Jan 24, 2004 | 04:49 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
It will if you use a v8 bellhousing and v6 clutch setup, but I would not recommend that.
Old Jan 24, 2004 | 05:58 PM
casper975's Avatar
Car: 1989 Camaro RS
Engine: v6
So I should just stick with the auto tranny thats already on the v8
Old Jan 26, 2004 | 10:06 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
yes and do a search, this has been talked about like 89674985698365935853984654389 times, im sure you'll find more information.
Old Jan 27, 2004 | 01:06 AM
matts90firebird's Avatar
take a look at my web page
www.cardomain.com/id/matts90firebird
i did a 3.1 tpi to a 350 carbed
i swaped teh 700r4 to a th350
i am in the process of putting a 383 turbocharged monster in front of a moser 9 inch i will be rebuilding my th400 i got for free
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
