distributor/ignition question
Old Jan 26, 2004 | 06:45 AM
91tirespin's Avatar
Car: 91 camaro rs
Engine: 355
I'm doin a 350 swap in my rs and ordered a pertronix flame thrower HEI distributor and a MSD 6AL ignition system. Is there anything I need to modify to get these two to work together, do I need to just get another distributor, or do they work together fine?
Old Jan 26, 2004 | 11:20 AM
ede's Avatar
ede
why didn't you get a msd distributor? then it would of been more or less plug and play. no idea how the two parts you picked wil lwork together. the msd stuff will have a lot of instructions for all the differant applications.
Old Jan 26, 2004 | 11:40 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
You can hook an MSD box up to just about any distributor but, as ede says, you coulda bought the cheapo MSD Probillet thats "requires an MSD 6 or compatible box" ...Probably woulda been cheaper and woul definately be easier to install.
Old Jan 28, 2004 | 04:13 PM
91tirespin's Avatar
Car: 91 camaro rs
Engine: 355
I figured it out. I called MSD and the guy told me all I needed was a 8 dollar wiring harness that directly connects between the hei module and the 6al ignition box.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
