couple of Q's
Old Jan 28, 2004 | 10:38 AM
young82z28's Avatar
Car: Camaro
Engine: lt1
Transmission: 4l60e
Axle/Gears: 3.27 9 bolt
couple of Q's
I was thinking of eventually maybe putting a cam. in my carbed 305. I already have headers,intake, and 600 cfm carb. What is a nice cam for a daily driver. I have the crap heads with 1.74 in. valves but I'm not looking for a monster, just i nice boost in power. What kind of power would I make.I have a th350 trans and a 3.23 rear. Was thinking the summit cam with 420. in. Anyone with similar set-ups, wondering about top speeds, redline, and gas milage.
Old Jan 28, 2004 | 01:05 PM
Battery's Avatar
Car: 75 & 82 Z-28
Transmission: Saginaw 4 speed
A summit cam will work. Should probably see some good gains without having to mess with your heads. If you are going to upgrade your heads anytime soon I'd start looking into some of Comp Cams Xtreme Energy or Crane. They make cams that have proven themselves. Not to mention, 150$ for the cam and lifters.
As far as summit goes though, expect some gains but dont worry about fuel mileage or redline or any of the above mentioned. You may have a little bit more power up top, and maybe a little bit more top end which you will be able to tell, but not a huge change.
Old Jan 29, 2004 | 10:08 AM
young82z28's Avatar
Car: Camaro
Engine: lt1
Transmission: 4l60e
Well, what I was wondering is what rpm's people are running at highway speeds with a similar setup. Thanks
F-body-fan
Jan 12, 2023 01:49 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RedLeader289
May 28, 2019 01:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Linson
Oct 1, 2015 09:50 PM
