how to mount 4th gen radiator
Old Jan 29, 2004 | 11:07 AM
Electromaro's Avatar
i have almost completed my lt1 swap. all i need is exhaust and cooling. i have a 4th gen radiator and dual fans. i'm not sure how to mount it however. i'm not sure what it is called, but it i only have the top plastic piece from the 87 camaro. the piece that covers the top of the radiator and screws into the metal. anyways, how do i make it fit. also i need help with hose connections. i have not idea which hose goes where. thank you
matt
Old Apr 15, 2004 | 01:43 PM
please i need help
Old Apr 15, 2004 | 01:50 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Don't know, I stuck with my stock radiator, you can still go that route, just buy a upper and lower 93 z28 hose. As far as the fourthgen radiator, it takes fabrication to work, so just go creative on whatever works, its not a bolt up.
Old Apr 15, 2004 | 02:17 PM
Drastius's Avatar
Car: 1985 Camaro Z28
Engine: Caprice LT1
I believe the dual fans have a special plastic mounting pieces
Orr89RocZ
Apr 25, 2016 08:28 AM
Omega
Oct 1, 2015 02:20 PM
sreZ28
Aug 14, 2015 07:48 PM
Elliswon
Aug 10, 2015 12:33 PM
