best 305 cylinder heads.
Car: 84 Trans Am
Axle/Gears: 9in 4.30's
opinions of any cylinders used on a 305.please include other mods and info on the rest of the engine. cam, bottom end, intake
thanks
EDIT...this includes aftermarket heads..
thanks
Car: 4
Engine: 6
Transmission: 5
The ones you have are about as good as they get. Should be 416s. Same casting as LG4, Cross-Fire, etc. in all cars including Caprice, Monte Carlo, Cutlass, etc., and the 85-86 TPI 305s.
Transmission: 4L80E/4L80E
Ported World S/R Torquer 305's are slightly better than ported 416's or 601's.
I went with the Worlds because they start out as performance-oriented heads (rather than mass production) with thicker deck, 1.94" intake valves, and screw-in rocker studs; and I wanted to reduce down-time for the upgrade process. They do need some basic bowl-area porting to begin to realize their potential, though.
Car: 88 IROC
Car: 4
Engine: 6
Transmission: 5
I would think the LB9s on the newer TPIs would be better than those
Car: 83 Brlntta in Z28 clothing
Engine: 305 LB9 POS until 350....
Transmission: hurting 5 spd- Crunchy...
no to stray off topic, but if you consider the cost of buying a good set of heads then porting them, you may want to consider a healthy used 350. Cubes=Power I looked into building my 305 and IMHO it's not worth it. For the cost of building it up I can find a rebuilt 350 and then have a much stronger starting point.
-Z-
-Z-
Car: 84 Trans Am
-Z-
-Z-
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
Originally posted by 84H.O.Trans Am
they i have to worry about the exploding t-5 from the torque.
Car: 84 Trans Am
Originally posted by robertg
:shrug: you can blow up a t-5 just as easily with a 305.... i don't see how that is a valid point.
And both of these points bring me back to my original point of "Built 305" vs "Rebuilt 350"-- My T5 is in rough shape and has only had the stock non-HO 305 put through it. 120 horse, I think. Any engine can damage a tranny if enough burn outs are logged. I'm not building a strip car either, just something w/some cajones. And it's easier to build a 350 than a 305, because you start off stronger with more cubic inches. Good 350 heads can work on a 305 and vice versa, it's just in the tuning and the carb setting yadayada..... but my point is that if money happens to be a factor, it's better spent on the overall package rather than picking a single part of an already weak combination to beef up.
-Z-
-Z-
509 camaro fan
Sep 6, 2015 10:43 AM
