Torque Specs
Car: 1986 Trans Am
Engine: 5.7L TPI
Torque Specs
I'm finnaly finishing my 350, and am now just bolting stuff back on it, i cant find the torque specs for the intake and such anywhere though, does anyone know the torque specs for intake manifold to the block, runners to intake, plenum to runners and tb to plenum ?
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Your torque on the intake manifold bolts is 35 foot pounds, The runner bolts is 25 foot pounds, and the exhaust manifold bolts are 20 foot pounds, fuel rail to manifold bolts are 15 foot pounds, and throttle body to plenum is 18 foot pounds.
The Trickster!!!!!!!!!!!!!
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yes, that is for a TPI Set-up as far as the torque on the runners, fuel rail, and throttle body, the torque on a TBI throttle body is 16 foot pounds and the nuts for the fuel lines are 22 foot pounds, the torque on the intake and exhaust manifolds are the same for both set-ups on a stock factory engine. With the modifications listed in your signature Shifty, your torque values might be different and used according to the Edelbrock specifications.
Car: '90 RS
Engine: 377 LSX
Yes, that is for a TPI Set-up, the torque on a TBI throttle body is 16 foot pounds and the nuts for the fuel lines are 22 foot pounds.
no green
Jan 9, 2016 09:22 PM
thanks a bunch
