89 305/350 TPI swap
Old Feb 4, 2004 | 11:05 PM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
89 305/350 TPI swap
Hi all,
I'm planning on buying a 305 TPI TA this weekend. I've gathered alot of info so far for the 350 swap. I'm going to use higher compression pistons, a medium cam, and port the heads. I've removed and overhauled stock engines before just never swapped anything with fuel injection. Please correct me if I'm wrong on anything.
Buy a 87-89 camaro/TA 350 so it uses MAF and the intake bolts line up.
Replace with 22lb injectors and 350 PROM.
Replace motor mounts.
Questions:
1) I cannot find an aftermarket PROM for 350 TPI manual (because they did not exist), which should I use?
2) Do I need to upgrade the fuel lines and fuel pump?
3) What years of 350 heads will be compatible with my intake?
Thanks.
Old Feb 5, 2004 | 06:22 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
1) Use an aftermarket chip.
2) No.
3) '87-up iron. Stay away from LO5 heads.
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
