EGR Block off plate for 95 LT1...What all do I need?
Old Feb 12, 2004 | 02:17 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Do I just need the block off plate or is there more to it? Where can I get one? Reason im removing it is because I have some 82-92 headers and the LT1's EGR line goes to the exhaust manifold not to the block like our motors. Thanks.
Old Feb 12, 2004 | 03:34 PM
ede's Avatar
ede
i make them from a piece of sheet metal, 11 or 16 ga and a gasket
Old Feb 12, 2004 | 03:45 PM
pasky's Avatar
Just need to make one where the tube goes from the intake manifold right? Considering I don't have to block it off from the exhaust manifold, or is there one im missing?
Old Feb 12, 2004 | 07:52 PM
TexasLT1's Avatar
Car: '92 RS
If you're putting on headers that don't have EGR then dont worry about that end. There is one on the back on the intake that you will have to block off right beside the EGR valve, which I would block off too. I've used 1/4" steel for mine.
Old Feb 12, 2004 | 07:55 PM
pasky's Avatar
Thanks Texas.
Old Feb 14, 2004 | 07:58 AM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
I made mine out of a $.19 electrical box cover. It's thick and easy to cut with a dremel. I used some RTV and it works perfectly.
Old Feb 14, 2004 | 10:37 AM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
A friend of mine (machinist) is making 1/4in. aluminum blockoff plates and selling them for $25, drop me an email if youre interested.
Old Feb 14, 2004 | 12:19 PM
pasky's Avatar
LoL, no offense to your friend, I know were all out to get money, but uhh, not for no 25 bucks.
Old Feb 14, 2004 | 04:37 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Its cool, just thought Id give you another option.
Old Feb 14, 2004 | 06:19 PM
SERPENT99's Avatar
Car: 89 IROC
Engine: 95 350 LT1
if you have headers without the egr hookup then you only have to cover the upper square hole right under the egr valve. No need to cover the hole where the tube hooks to the manifold if you block off the top hole under the valve. I leave the other 2 holes open, if you cover them you're just trapping hot air inside the manifold. The easy way is to loosen ther egr valve, then slide a thin piece of metal between the valve and manifold to cover the top hole, then clamp it in place with the valve. If you really like the hacked ghetto look you can whack the diaphram off the valve.
Old Feb 14, 2004 | 07:55 PM
pasky's Avatar
I didn't quite understand what you meant in that reply.
Old Feb 14, 2004 | 10:25 PM
SERPENT99's Avatar
Car: 89 IROC
Engine: 95 350 LT1
which part?
Old Feb 14, 2004 | 10:55 PM
pasky's Avatar
Upper square hole under the EGR valve?
Old Feb 15, 2004 | 12:01 AM
SERPENT99's Avatar
Car: 89 IROC
Engine: 95 350 LT1
remove the egr valve, there's 2 holes under it. The square hole on top is all you have to plug up. Just put a little piece of metal over it and put the egr valve back on top of it to hold it in place
Old Feb 15, 2004 | 12:53 AM
pasky's Avatar
Oh cool, so just do that and leave everything else as is?
Old Feb 15, 2004 | 11:46 AM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
This is the one I was talking about blocking off:
Attached Thumbnails EGR Block off plate for 95 LT1...What all do I need?-rrengine.jpg
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
rudolphschenker
Sep 4, 2015 02:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
tonys91rs
Sep 2, 2015 07:07 PM
