building motor questions
Old Feb 20, 2004 | 03:42 PM
harryo's Avatar
Car: 1989 chevy trk4x4,1994Z28
Engine: 307to400 (colector)
im going to build a motor the block is a 350 from a 1988 chevy truck. the questions are: are the speed pro pistons (h618cp30) a good piston?it has a .125 dome.edelbrock etec heads are they emmissions leagal?
Old Feb 20, 2004 | 06:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Those would be a terrible piston choice. With those heads, and even with a typical factory block deck height, your compression ratio will be about 12.4:1. Very bad for street use.
This is the piston you should use. http://store.summitracing.com/partde...STL%2DH345NP30 or http://store.summitracing.com/partde...TRW%2DL2256F30 With either of these, your CR will be around 10.5:1.... must better for the street.
For legality questions, see http://www.edelbrock.com/automotive/headsbchev.html
Old Feb 20, 2004 | 06:01 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
You do not ever want to put domed pistons in and engine. They cause all sorts of flame advance and travel problems. Its much better to get smaller cc heads and flattop pistons.
Old Feb 20, 2004 | 07:05 PM
harryo's Avatar
RB83L69the article said them pistons with 64cc heads will be 10.72 cr on a 9.025 deck im going with a floating pin either powder rods or eagle there about the same price. a crank that is good to 500 hp the heads that i will be using first will be vortec heads(193) then i will go to alluminum latter on i looked at edelbrocks web site already icant use the performer heads cause they only fit to 1986. i cant use the performer centerbolt cause they are 60cc, i dont know if the compresion would be with 60cc heads & flat top pistons.the etec heads i dont know if they are emisions legal . where i live they just past a law that youre pullution equip. must be on for a visual inspection
Old Feb 20, 2004 | 07:22 PM
harryo's Avatar
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
italiano67
Dec 11, 2016 09:21 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
