Building a 357 engine, need help/advice
Old Feb 20, 2004 | 07:32 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Having a 357 built, would like to put a set of vortec heads. Need advice from fellow TGO members as to what roller cam /vortec heads to install. Should I use a holley 670tbi or GM's 454tbi? Any other advice you can give would be appreciated.
Old Feb 26, 2004 | 11:09 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
If you go with TBI regardless of the size, it will limit you on your cam selection, if I remember correctly TBI does not like big cams, it's difficult to tune them, which will be the next step. There are several people on this board with mild-built 350 TBI engines. I don't know enough about them to make any recomendations than I already have.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
italiano67
Dec 11, 2016 09:21 AM
sreZ28
Aug 14, 2015 07:48 PM
TreDeClaw
Aug 14, 2015 06:58 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
