LT1 Performance Cam ?
Old Feb 22, 2004 | 10:21 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
For a daily driver which would be the best cam for my LT1?
Comp Cams XE 230/236
Or CC 306?
Any other suggestions?
Old Feb 23, 2004 | 08:38 AM
TexasLT1's Avatar
Car: '92 RS
Both the cams you suggested are great cams that make some great power, but you are going to NEED ported heads to really take advantage of either of them. If thats not a problem, they are both very similar, with the CC306 being a more high RPM cam while the 230/236 has a little more low end grunt. In two identical cars these cams would run very similar times. If you want something a little bigger, check out the GM847 cam. Something smaller, go for the Hotcam or CC305.
Old Feb 23, 2004 | 09:21 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
TexasLT1 nailed it. The CC306 is a monster and really likes ported heads and a lot of revs. The CC305 and hotcam are better suited for all out street use. Check out www.camaroz28.com and see what kind of cams those guys use for their street cars.
Old Feb 23, 2004 | 05:10 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
So would either of these cams cause a problem being used on stock iron heads for a while? I want to hurry up and swap the LT1 in and I figured it'd be easiest to swap cams while it's out of the car. Either ported heads or AFR's will be in the future for sure, but I don't have the $$ to invest before the swap. So will either of these cams cause any major problems being used with stock heads?
Old Feb 23, 2004 | 05:14 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I take it you have an iron headed LT1? If so I am not sure what the max lift is for those heads. If they can take the lift of either of those cams then they will work. i would try to do some research on www.camaroz28.com to find out for sure. You are going to want to have the ECM reprogrammed though. You may have some driviability problems with those cams on a stock tune.
Old Feb 24, 2004 | 01:45 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Go w/ the xe230/236. The 306 is an older design cam, w/ lazier ramp rates. You can tell that by comparing the two cams by duration at .050 and advertised durtaion
XE - 230/236 @ .050 - 281/287 advertised
306 - 230/244 @ .050 - 290/207 advertised
the XE will idle better w/ better vacuum than the 306 and the 306 will have to be spun higher to make power.
Not saying that the 306 isn't a good cam. A ton of guys are running it w/ great success. I just like the XE grinds better.
midge54
Dec 27, 2019 04:14 PM
beastin91rs
Oct 9, 2015 07:38 AM
midge54
Aug 29, 2015 09:51 PM
ambainb
Aug 29, 2015 12:43 AM
theshackle
Aug 22, 2015 06:52 PM
