vortec swap
Old Feb 22, 2004 | 10:47 PM
walterrao's Avatar
Car: 91 RS
Engine: vortec 355 hsr
Transmission: wct5
Axle/Gears: bg3.27
vortec swap
Im currently building a vortec 350. I need to know if the pistons are the same in this engine as in other 350s. I was told there are different part numbers for the pistons in this engine, but i would think they are all the same. i am lookin at speed pro forged pistons in summit, part # trw-L2256F30. Can anyone tell me for sure if these would fit before i waste my money on them.
Old Feb 23, 2004 | 11:25 AM
unknown_host's Avatar
Car: 1989 Iroc Z L98
As long as your motor is .030 over and you are running a 5.7 connecting rod you should be fine.
Some things to take note of:
Vortec cylinder heads CC a lot less than their rated 64cc, mine came in at something like 61.7
That should put you right at 10:1 compression, so you arent going to be getting away with 87 octane with cast iron heads.
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
z28addict8490
Sep 5, 2015 03:56 PM
earlpote
Aug 28, 2015 10:42 AM
jharrison5
Aug 19, 2015 05:53 PM
