Want to swap 305 TBI to 350 TPI need some advice
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
Would I be better off buying a used motor and haveing it rebuilt or should I buy a new GM short block?? Also has anyone bought a used 350 TPI speed density setup from any of the sponsers on this board?? If so were you happy with your purchase?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It really depends on the condition of the motor. There may be a reason why it was in a yard. It is always good insurace to dissassemble it, rebuild it and have the regular checks done to it. You will come out with a new engine practically. You don't want to take any shortcuts on an engine you nothing about.
