400 options
Old Feb 23, 2004 | 07:07 PM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
400 options
This is mainly to get a few opinions on how to configure my 400. First I'm going to be using a worldcastings or a dart block. Which is the better one to get since they are both within $200 of each other? Second, both blocks are available with 350 or 400 main bearing sizes. Which one has a wider selection of cranks available? Should I run 5.7 or 6.0 rods? This is going to be used as a street engine for at least 90% of the time so I would like to get 80K miles out of it.
Old Feb 24, 2004 | 12:22 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Re: 400 options
Well it's your money, but I wouldn't bother getting a Dart block if I didn't plan on getting radical, but that's me.
That being said, there's a few setups I know of to use with one of those blocks....they can be bored/stroked to a 427. I may be wrong but it seems I've heard of making a 454 with one of the aftermarket SB's also.
But 80K miles on those setups??? I don't think so. Sure would be a blast if you could afford enough gas to drive it 90% on the street!! lol
Old Feb 26, 2004 | 11:01 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
How radical are you wanting to get? Is there any reason you are goind with an aftermarket block, is it because you can't find a 400 block or do you want to stroke it to 427+? I used 5.7 rods in my 400, you can use 6.0 but I think the oil control ring might be down around the wrist pin, there's debate on if that hurts perfromance and oil consumption. I had to grind on the back side of the rod bolts to clear the cam. If I had used cap screw rods I wouldn't have any problems at all. As far as crankshafts go I think the most options are for the 400 main 5.7 rod versions, I could be wrong though. There's a bunch of parts out there.
If it's a street engine and you want 80k miles out of it, it's going to be next to impossible to make it radical and have good longevity, I'm not saying it can't be done.
Good luck.
Old Feb 27, 2004 | 09:20 AM
eric305TPI's Avatar
I'm wanting to use a aftermarket block since I'm having trouble finding a block. I'm planning to make it a mild setup that wont spend much time past 5000 rpm, but that may change due to the fact that I have 2 cars.
Old Feb 27, 2004 | 12:51 PM
LilJayV10's Avatar
Engine: 406 Roller
If you are not going to spin it past 5000rpm it will be a tame engine with lots of tourqe if you pick the cam right. I think the 5.7 rod would give you the most choices as far as crank's and pistons. You could get lucky and find a complete 400 like I did, I did get pretty lucky though, I got it for 200 bucks and it was running. I tore it down and was glad I did because a ring had broken and scratched the cylinder wall badly. Finding a complete engine would be the cheapest way, then you would have the block and crank, buy a set of recondition rods from northern automotive performance with good bolts for 100 bucks(thats what I have in mine)a set of KB pistons, $286, a complete rebuild kit from northern automotive, I think it was around 165, plus machine work and you'd have a good bottom end for what you are wanting to do with it. Heck thats the bottom end I have and I spin it to 6k all the time.
Good luck
Jason
Old Feb 27, 2004 | 01:14 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
You're in Texas and you can't find a 400 block?!? There are several sources for them in the Southwest where shipping won't kill you.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33613
http://cgi.ebay.com/ebaymotors/ws/eB...category=33615
There's at least two others currently on eBay. Here's another good source.
http://www.racersauction.com
PM me...I'm going to Houston during Spring break. I might be able to land one for you.
Old Feb 27, 2004 | 08:32 PM
eric305TPI's Avatar
I just found out that I might be able to get a complete running 400 (standard bore) from pan to intake for $500. It would be from a friend in Colorado but it may be worth it still to look into.
F-body-fan
Jan 12, 2023 01:49 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
gixxer92
May 18, 2017 11:20 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
