distributor/ignition question
Old Feb 24, 2004 | 05:31 AM
91tirespin's Avatar
Car: 91 camaro rs
Engine: 355
I swapped a carbed 355 into my 91 camaro(previously 305 tbi). I got msd 6al ignition, and aftermarket non computer controlled hei distributor. I read in an article that the large red/pink wire from the old coil goes to the BATT connection on the distributor. But the msd instructions say to route the red wire from the ignition box to that same wire. What do I do?
Old Feb 24, 2004 | 10:06 AM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
that large pink wire goes from the original coil to the key on/off
take the small red wire in the msd (ignition wire) and solder it to the large pink wire..that pink is the old coil wire so when u key up power will be sent trhough that right into the box....i have mine like and everyhting is cosher
Old Feb 24, 2004 | 11:47 AM
91tirespin's Avatar
Car: 91 camaro rs
Engine: 355
do i need to run a wire from it to the distributor as well?
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
