Wiring harness
Wiring harness
Im swapping the 2.8 MPFI engine out of my 88 camaro and putting in a carb'd 350. Does anyone know where i can find a wiring harness to complete the swap. All of the accessories and everything came off an 84 if that helps at all. Local junk yards dont have any salvagable harnesses.
Transmission: 4L80E/4L80E
Unless the 350 is computer controlled, you can use your existing harness (with a couple of wire "stretches") to run the 350.
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
i have an 87 camaro, swappin to carb, so took comp out, what do i need to strech to hook up, or nothing, tel me b4 i go insane
Car: 87 IROC Z28
for your troubles you can get a gm wiring harness from painless wiring, thats all, its a closed loop harness so you dont need anything else but it...look around for it at their site..www.painlessperformance.com
i htink thats the site
