Pre-85 block or new LT1-LS1
Old Mar 10, 2004 | 11:16 PM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
Pre-85 block or new LT1-LS1. Is the hastle of swaping in a new LT1 or LS1 worth it? Is it better and the old style engines? My L69 is carbed so it must be carbed. No EFI...
Old Mar 10, 2004 | 11:43 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Pre-85 block or new LT1-LS1
It depends on what your goals are and what you mean by better.
Old Mar 11, 2004 | 12:35 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
if it "MUST" be carbed,,why I dont know..buy a JY 350 and go from there.....no scence killing a LT-1 or LS-1
Old Mar 11, 2004 | 02:08 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Whats your existing motor having a carb have to do with what you install ?
Old Mar 12, 2004 | 03:46 PM
because I don't want to deal with installing all the electronics that come with EFI...Plus, carbs are easier to tune.
Old Mar 12, 2004 | 04:02 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
It all depends on what you are used to . I can tune EFI all day but am clueless when it comes to carbs.
Old Mar 12, 2004 | 05:44 PM
Ok....forget about induction for now. Is there any benifit from one to the other about the engine blocks or gemometry that make one better than the others? Or can any one of them produce the same amount of power. Are the new ones more fuel efficient in any way? Thats what I mean by better...
Old Mar 12, 2004 | 05:56 PM
TexasLT1's Avatar
Car: '92 RS
I have a 400 hp LT4, I'm getting about 15 mpg around town and 25 on the highway, gotten 30 once. I have a T-5 with 3.42 gears.
LS1's are getting even better gas mileage.
Also, since you have a carb car, it will actually be easier to swap in since the wires that you need to splice in are the only ones in the engine compartment as it is.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
skinny z
Oct 5, 2015 06:23 PM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
