couple of LT-1 questions
first---How much fuel pressure does the LT-1 injection system use,
second---will the stock injectors and throttle body support a 383 sbc.??
third--- whats the best way to bypass the VATS system in the factory computer, I have no way of knowing what the key resistance was.
thanks in advance.
thanks in advance.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: couple of LT-1 questions
thanks in advance.
thanks in advance.
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
I second that, another option if you dont want to send your computer off is look up the VATS bypass on ebay, think a guy sells them for $15 its a plug in little electronic module. He has a lifetime warranty on the thing, would be a temporary solution.
