head porting
Old Mar 15, 2004 | 09:17 AM
mmcdjs's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.1 V6
head porting
Hey, has anyone done a porting job on a set of 193 heads before? I'm looking at doing that on my set, and remove the swirl spur on the intake bowl. do you think that this will help with the flow on these heads?
Old Mar 15, 2004 | 09:54 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You will spend more in die-grinder bits than you can get a whole set of heads without the ramps for.
And, I would assume your time is worth something to you.... I know mine sure is.... I wouldn't waste that much time to save that little money.
Get a set of 081 heads and be done with at least that much of the work.
Old Mar 15, 2004 | 11:28 AM
mmcdjs's Avatar
Engine: 3.1 V6
well. time wise. it takes about 10 minutes to completely remove the swirl tab, I'm using a carbide bit and it's still sharp as nails.
Old Mar 15, 2004 | 04:57 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
https://www.thirdgen.org/techbb2/sho...hreadid=177465
Old Mar 15, 2004 | 06:08 PM
mmcdjs's Avatar
Engine: 3.1 V6
that's a lot of good information, but it doesn't say what would happen, good or bad, if I removed the swirl tab. I just did that to the set of 193 heads that I have.
LT1Formula
20
Nov 14, 2015 12:02 AM
italiano67
Aug 31, 2015 06:04 PM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
