LT1 wireing questions
Old Mar 16, 2004 | 11:01 PM
Air's Avatar
Air
Car: 91 camaro
ok i have been reading you boards for like a week straight on swaping a LT1. i'm getting ready to do it to my 91 V6 camaron using a 97 LT1 with a T-56. i'm not worried about getting the engine to fit, its the wireing that kinda worries me.
i have a bunch of question that if any one could answer i would greatly apprciate it.
i have a complete donar car and all the wireing. My first question is when i swich the engine over and use the LT1 computer, is the ABS system part of that ?? Second, is there any way i can use my stock Guage cluster? like will the harness connect to my guages? Third, should i completely gut the wires out of my V6 and just use the new harness? or will the new and old harness work together?
what do i really need to know about the wireing harness to make this work?? any tips or tricks i should know before i start
and i have heard the 97 harness is different from the earlier LT1 harnesses, is this true?
also if you have the wireing schmatics i need would you please let me know
i'm know i have more questions but i can't remember them now.
Thanks alot
here you can see my car and my donar car
http://www.cardomain.com/memberpage/515485 ::
Old Mar 18, 2004 | 07:47 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
https://www.thirdgen.org/techbb2/sho...readid=176800:)
Old Mar 12, 2007 | 01:31 PM
96j350ta's Avatar
Car: 96 Trans Am
Engine: Lt1
Transmission: UNKNOWN AUTOMATIC
Axle/Gears: posi or lsd with 3.74 gear
Help please
I have a 96 Trans Am with a Lt1 in it i have the four wire Oxy. sensor with white, purple, and two browns/tans I need help on finding out which is my signal wire.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
