LG4 same as 305 Camino
Old Mar 22, 2004 | 01:17 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Is an LG4 Camaro engine the same as an 87 305 El Camino engine? Any differences? Thanks.
Old Mar 22, 2004 | 05:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Depends upon what LG4 you're comparing it to.
If '84-earlier, the '87 will have higher compression and knock sensor. If '85-earlier, the '87 will have one-piece rear main seal vs. two-piece. If '86-earlier, the '87 will have roller lifter cam, center bolt valve covers, and 72 degree angle center intake manifolt bolts vs. flat-tappet cam, perimeter bolt valve covers, and 90 degree intake manifold bolts.
However, that's based on f-body info. The El Camino could have other differences, of which I'd have no clue. But the basic 305 should basically be the same.
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
buffaloman
Firebirds Wanted
Sep 7, 2015 09:47 AM
buffaloman
Camaros Wanted
Sep 7, 2015 09:46 AM
Formula_88AE
Sep 3, 2015 01:47 PM
