swapping my motor
Old Mar 30, 2004 | 08:08 PM
trans_am_ta_84's Avatar
Car: 89 trans am
Engine: 355
swapping my motor
hey guys i'm in the process of my motor swap
305tbi to 350tbi..
question is i'm using 305 tuned port heads with the 350 and the push rods are longer on the 350 engine.. do i use the longer 350 push rods or do i use the 305 push rods?
Old Mar 30, 2004 | 09:14 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
was the 305 a roller motor?
is the 350 a non roller motor?
if yes to both
use the non roller pushrods(350)
Old Mar 30, 2004 | 09:21 PM
Car: 89 trans am
Engine: 355
the 350 was non and the 305 was roller..
and now i've relized that the solid lifters are shorter and needs longer pushrods then the short roller lifters
Old Mar 30, 2004 | 11:22 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Just to be clear, the 350 didn't have "solid" lifters. It had flat-tappet hydraulic lifters (the factory hasn't used solid lifters since the early 70's - as far as I know, they never used roller solid lifters in production engines). '87-up (passenger car) used roller hydraulic lifters.
Anyway, you use the pushrods that are the correct length for the type of lifters you're using. Factory flat tappet push rods are longer than those used with factory roller lifters.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
E Rod
Aug 28, 2015 05:17 AM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
st.evel07
Aug 13, 2015 06:15 PM
