86 305 TPI --> crate 350
Old Mar 30, 2004 | 09:37 PM
F-Body Tim's Avatar
Car: 1986 IROC-Z
Engine: 305 T.P.I.
i finaly realized it is not worth it to build a 86 305 TPI, which is in my car right now with 66,000 mi. so i bought a totaled 87 chevy truck with a 350 crate motor which had 45,000 mi. on it, it was only $400.00 for everything that was on the truck . so we pulled it out and the 350 is in my garage floor, next to my car .
Old Mar 30, 2004 | 09:42 PM
F-Body Tim's Avatar
Car: 1986 IROC-Z
Engine: 305 T.P.I.
my plans for this motor is to trash everything except the block . this is to make way for the forged 383 project :rockon:.
so does anyone know a ruff estiment to machine my 350 to a 383.
Old Mar 30, 2004 | 09:46 PM
F-Body Tim's Avatar
Car: 1986 IROC-Z
Engine: 305 T.P.I.
ill get some pics of the motor soon...
here is what the 350 is going into.
Old Mar 30, 2004 | 11:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Looks like a worthy recepient.
Which "crate" 350? Goodwrench?
If so, the block is about all that you're going to be able use. And, have it checked very carefully for cracks and cylinder wall thickness before you let them spend any of your money on it. Machining costs vary, you really need to check around in your area. It'll probably cost more to have them clearance the block than it will to do the other "normal" machining.
I haven't seen them specifically, but you might consider a stock-bore kit if the cylinders are in good shape. You'd end up with a 377, but the extra 6 cid doesn't make that much difference. Then you'll have the .030" there for the next rebuild.
Old Mar 31, 2004 | 11:57 AM
F-Body Tim's Avatar
Car: 1986 IROC-Z
Engine: 305 T.P.I.
i'm not shure one what brand the block is, all i know is the block was bought new, block had 0 mi. and was never in a car before, from GM.
i only need the block, i am replaceing all of the internals with forged internals
Old Mar 31, 2004 | 01:06 PM
five7kid's Avatar
The Goodwrench 350 is a new GM long-block. Typically made in Mexico. Typically used as an economical replacement engine, often in trucks (there's one in my '84 full-size van).
The "Mexico" and "economical" parts are where you need to be careful. Casting quality isn't always the best. Even a .030" overbore can be a problem for a high-output engine.
I'd highly recommend a check for cracks and sonic cylinder wall thickness check before you spend any machining money on this block. In fact, I don't recall ever hearing of anyone who has turned one into a 383.
gta90
Sep 15, 2015 04:00 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
