Strange Vibration after new engine install!!!
Old Apr 4, 2004 | 12:21 AM
snowman89's Avatar
Car: 1989 IROC-Z Camaro
Engine: 5.8L 355
Transmission: T-5 5-speed
Ok well first off, I seem to be experiancing vibrations from somewhere I have ideas to what it could be. So I need some other ideas.
Ok I just recently dropped a 76 350 block in my car, still has tpi, changed cams, bigger cam, forged pistons, ported and polished heads.
Well when I had to get a flywheel I had to use a flywheel off a 85 305 camaro. Well I don't know if its the Flywheel or not thats causing it. Could it just be the cam is bigger, or something. It has the orginal prom for the 305 that I had in it, and I haven't recieved my new prom yet that I had custom burned to my engines specs, so maybe its just the rough idle or something I really don't know, but the car has a vibration that is fairly noticeable, but doesn't really vibrate bad when at higher RPMs. Any ideas??????If you have an idea drop me a note, thanks guys!!!!!
Tyler
__________________
Old Apr 5, 2004 | 05:05 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Shouldn't be anything about the fact that it's an '85 flywheel that could cause vibration. Loose stuff is a different story.
Did you replace the clutch or any components?
Is your alternator loose? (There's a story behind that.)
You didn't really describe the vibration, other than it isn't as bad at high RPMs. Are you sure it's firing on all cylinders?
Old Apr 5, 2004 | 05:19 PM
LedZep's Avatar
Car: 1990 Formula Firebird
Engine: 305TBI w/ Functional Sport Hood CAI
Axle/Gears: SLP Posi and 3.23 Gears
If the flywheel is lighter or heavier than the orig. it could throw off the balance of the engine (causing vibrations). Atleast this is what I was told..
Old Apr 5, 2004 | 05:29 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
SBC's are neutral balance(with a few exeptions, 400, 86 up 1 piece RMS), flywheel wieght should have nothing to do with vibrations, unless combo is stroker w/balancing done w/flywheel/damper.....i.e, external balance
Old Apr 5, 2004 | 05:32 PM
LedZep's Avatar
well I learned something today
Old Apr 5, 2004 | 08:50 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
The 305 had a different heavier harmonic balancer in the front. Assuming they maintain a zero balance then the flywheel would have to be heavier.
Does the engine virbrate excessively in nuteral? it's possible the flywheel itself is out of balance.
Old Apr 5, 2004 | 11:28 PM
five7kid's Avatar
Not true. The balance isn't front-to-rear.
Vintageracer
Jan 10, 2020 05:33 PM
red90IROCls1
Aug 25, 2015 06:56 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
