LT1 fired up! :)
Old Apr 6, 2004 | 07:09 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
LT1 fired up! :)
Just got the car started turned the key and heard the massive power of a open header LT1. However I idled at 5000 rpm lol. I think i hooked the vacuum lines up wrong from the regulator to the intake manifold:
http://shbox.com/1/fp_reg.jpg
I put mine on the top instead of the bottom, I would check myself right now but im stuck at work for another hour. Is this the problem of the 5000 rpm idle? Thanks.
Old Apr 6, 2004 | 07:35 PM
TexasLT1's Avatar
Car: '92 RS
Awesome man! As far as the vacuum lines, it doesnt matter which port they are plugged into, they all go to the same source. Something else is causing it to run high. Make sure your idle air control is plugged in, and that you don't have any other vacuum leaks.
Old Apr 6, 2004 | 09:23 PM
iroc-ice's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Transmission: 700-R4
Congrats on getting it started. Hope you figure out whats making her idle so high. And I thought I had idling problems(1500 rpm).
Old Apr 6, 2004 | 09:27 PM
TexasLT1's Avatar
Car: '92 RS
haha, helps when the car doesn't think its running 140 mph! gotta love datamaster
Old Apr 7, 2004 | 10:04 AM
Burn's Avatar
Car: 90 Iroc
Engine: 383LS1
Axle/Gears: 4.10
You did plug the unused vacuum ports in the intake didn't you?
Old Apr 7, 2004 | 08:35 PM
TexasLT1's Avatar
Car: '92 RS
found the problem. It actually idles now
RS Reaper
Oct 17, 2018 07:52 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
indygene
Sep 26, 2015 11:21 AM
sahlomonic
Sep 20, 2015 07:15 PM
