LT1 Swap Evap Can delete. ques.
Car: 89 GTA
Engine: 350 LT1
the steel line from gas tank to evap canister.. what can I do with it / is it needed?
thanks.
thanks.
Car: 89 GTA
Engine: 350 LT1
i doubt it.. return line should be 5/16 this is like 1/8 .. brake line I think.. plus its on the wrong side of car, plus how does it go into the tank?
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
It goes to the top right above the fuel level. The return goes all the way to the bottom as does the actual fuel line. I just did some work in my tank a couple months ago. There should be another tube coming out in the back of the car with a one way valve on it that vents the tank some way also.
1992 Trans Am
Aug 8, 2015 08:16 PM
