ground wires in the bellhousing
Old Apr 16, 2004 | 12:45 PM
84_berly_84's Avatar
Car: 84 berlinetta
can anyone tell me how many there is suppose to be I have a 84 berlinetta with a 305 and auto trans. also is therer anywhere else I can put them because my brother was trying to help why I was gone and tightened all the bellhousing bolts without putting them on there and it is a pain to remove the bolt
Old Apr 16, 2004 | 02:36 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
If thier just grounds, put them on the chassis.
Old Apr 16, 2004 | 02:41 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
or an intake bolt if you have a stud sticking up enough to put another nut on.
Old Apr 16, 2004 | 05:05 PM
Car: 84 berlinetta
no intake bolt I have headers installed and theres not enough room for another bolt. Will they be okay on the chasis??
Old Apr 16, 2004 | 06:23 PM
pasky's Avatar
They just need to be on a spot that gets a good ground, can be anywhere really. I mean if you must, just run a ground from somewhere else and put it where they all fit.
Old Apr 16, 2004 | 06:25 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
np on chasis. but you should have a braided copper cable connecting the engine to chasis as well.. if that's there ok.. otherwise maybe not because bat - is probably connected to the block. and block might be isolated from chasis via rubber mounts. but as long as there is some connection from block to chasis then there is no reason chassis Gnd is not as good..
Old Apr 16, 2004 | 06:28 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
I think pasky and I are at agreement lol must be on same time as me..
Old Apr 16, 2004 | 07:17 PM
Car: 84 berlinetta
thanks
cool.... thanks alot guys saved me one headache..
Glowsock
Jul 24, 2025 03:15 PM
eightsixseven
Dec 16, 2024 01:50 PM
Jae992
Aug 27, 2015 09:07 AM
Glowsock
Aug 26, 2015 12:28 AM
383backinblack
Aug 15, 2015 06:36 PM
