newer V6 to older V8
OK guys here we go. I took my 1987 camaro with the mpfi 2.8 and switched to an old style carb'd 350. In the process I decided to go with vbelts. Since I cannot find the brackets needed to make my newer style ac delco alternator work (its the small one) I am going to have to go with the old style alternator. The real problem I'm having is figuring out how to wire this thing up. There is a different number of wires on the plug. I know this seems like an electronics thing, but it does relate to my engine swap too. If i can figure this out, all I'll have to do is figure out how to splice in my HEI distributor.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Go to the "Carburetor" board and look for a thread called something like "Carb'd engine pics"... there are two threads, look at both.
They both have excellent pixctures of how it should look when wired correctly.
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
you need only 2 of the wires from the original v6 alt. loom I belive one is brown and one is tan I can look in the morning and tellyou exactly with a pic. you will need the plug of the older style to wire into,
almost done with mine,
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
